- 5:37 PM
- Apr 30, 2016
- Central CT
Pre-preg?
I'm going to draw a bar up in solid works and make some cuts in it. I can set the material to chromoly and check compressive force along with several other forces.
SOS, if you cut another bar I can tell you to avoid the square corners if possible. Even just a 1" corner radius would be better. I can explain more later, but I think you know what I'm getting at.
What I have here is what's used on school buses to bond the body sheets together, without the need for rivets. It's a Henkel product, and is what the engineers at Henkel recommended using. I just don't have the mixing gun for it on hand. I can borrow one from them, but I need to have the bar cut out and ready first.
The bars are about 5mm thick, so my idea was to have 2mm milled down from each side for the rim edge around the cutout. I was going to use 1.5mm or 2mm carbon and bond those in place, minimizing the amount of bonding agent and maximizing the amount of carbon used. I was forced to use 1mm carbon instead, as the cutout and rim edge wasn't perfect, and had slight variations in depth. Having the inserts flush with the rest of the bar was my main goal.
If you look back to the start of the first bar I did, you'll see the edges I had drawn were way more rounded than they ended up like. I was limited to what my buddy could do, and beggars can't be choosers.
