Homemade Reduced Weight Bar
SOS Ridgerider
Muffler Modded Member
6:03 PM
Central CT
The finish did not come out as well as I had hoped on this one. Last one looked better.
The steel had more imperfections and the JB Weld ended up filling in those imperfections, and I had a hell of a time cleaning it up. The carbon also delaminated in a couple of spots. It’s far from perfect, but I’ll actually use it, so it doesn’t have to be pretty. Good enough for who it’s for, right? Lol
7A5E00BC-4549-4B26-94D5-40628A06033D.jpeg 0FC0A182-28DD-4EAF-B9FC-0660ED0FB4E5.jpeg C35A20E4-B793-4ECC-A4DB-A0904EB729E3.jpeg 603AC286-EF38-469B-A9F1-3ECE9E744344.jpeg E9DF5F17-08EE-4175-91CE-93177BEE4353.jpeg
Adirondackstihl
6:03 PM
Upstate NY
View attachment 116301 View attachment 116302 View attachment 116303 View attachment 116304 View attachment 116305
I have a few Park Tool spoke wrenches :)
SOS Ridgerider
6:03 PM
Central CT
Graphite panels glued on one side or both?
LED lights in-between?
Looks great!
Philbert
Thanks! They’re 1mm carbon panels glued with JB Weld to each side. The void between the panels is also filled with JB Weld.
If you could machine them 100% accurately you could use thicker carbon and save some more weight. Unfortunately I don’t have access to anyone with a mill anymore, so I won’t be able to do this again and see what the results may be.
Most of these bars are just about 5mm thick, so if you left a 1mm rim in the middle, you could use 1.5-2mm carbon. Of the 8oz added after the cutouts were made, the JB Weld added the most of it. Less JB Weld and more carbon equals lighter.
Edit: I should have mentioned that I left more meat between the two cutouts compared to last time. I guess I could have saved a little more weight by not doing that, but I figured the longer bar could use a little extra help.
No led LED lights in between. That’s all Wayne @Dub11 Lol.
Jon1212
Birch! Please.....
4:03 PM
Utah, unfortunately.....
Instead of a sprocket nose, @Dub11 would use a chrome spinner wheel....straight outta da' hood.
