Kozak Logging
- 4:57 AM
- Jan 15, 2016
- Wisconsin
The homelite wiz... Not sure if its a 55, 66 or a 80/90 model. Thats the only killer I wanted to know. Has the hl46B carb. Ordered a hkl-88 carb kit I think it was. It will run if you pour gas down the cylinder but won't run off fuel tank. I took apart the carb and need and seat are clean. all the passages blew thru with carb and choke cleaner. Jets are clean...I'm pretty sure its just a stiff fuel pump diagpram gasket causing it. I noticed the 600D and model 17 have what looks like the same carbs as each other but is different than the wiz. The one has a brass fuel line and the other has a rubber hose thats cracked. Going to try to redo the fuel line and filters on the other two tonight and see if they fire, but I would guess they will need carb kits too.
