Boots
- 10:01 AM
- Nov 5, 2019
- Jersey Shore (not by choice)
So the answer is that the 4140 400 1308 will work for the 4140 400 1303a??? I am having the same problem, the saw shop sold me a 4140 400 1300b and it just backfires. And they won't take it back, they swear it is the correct one and that there is something else wrong with my trimmer. I check the compression witch is at 130#, keyway is good, muffler is good, this machine only has about 20 hours on it. I went to use it the other day and it fired then died. I bench tested the coil and it had no readings.
