Well here is my current bench with a 395 consuming it. Roughly 2x3
Need to come up with a better "system" and make room for "momma" to park in the barn.
I have an old "chicken coop" that is attached to my pole barn. Use it as a compressor/junk storage room. 2 60gallon+20 gallon storage tank.Fully insulated with osb on the walls.
Approx 9 widex14 deep 6ft to the side, open span center. figure if the compressors stay I am losing 2x5 of "saw" space.
Plan on running a pipe from the owb to a cast iron radiator for heat, and either move the compressors to the barn or build a sound wall around them.
Thinking an L shaped bench along 2 walls. 23ft of bench space. Proabably 2ft deep, not sure how high? probably sit on a stool for port work 36-8" ?
Would like to devide into stations,
1, clean/teardown
2, layout,grinding/port work.
3, assembly
4 chain grinder/ vice for hand filing.
That will leave me roughly 5ft of bench space for each section?
Thinking some kind of tub to hold each saw/parts in progress to go round the bench.
General tools required in each section.
Would love to hear what works/dosent from you guys. wall cabnets? shelves? bolt/parts bins? shelves vs drawers under the bench?
And if you are handy with a Floorplan software, some drafts would be awesome...
