helicoil size
jmssaws
Banneded
5:15 AM
Anybody know what size helicoil it takes for a 066 bar stud?
Thanks guys.
jmssaws
Banneded
5:15 AM
Groovy fellers, I didn't want to spend a 1000 on the wrong kit . lol thanks guys.
Jughead
6:15 AM
instead of helicoils for the plug go with an insert kit from auto zone.the kit comes with a tool to smack to spread the insert.the outer diameter has spikes that bite into the surrounding metal.
Keith Gandy
Maxima K2 40:1 87 Pump Gas
5:15 AM
Provencal, Louisiana
Sorry didnt see til after I posted
jmssaws
Banneded
5:15 AM
What keeps the bushings in place when tensioning the plug ?
Works the same as a helicoil, I put it on the plug then screw it in with loctite and run it. Not a great fix but I have used it when one is stripped bad
d.l.d
5:15 AM
Arkansas
The insert kits work awesome with stripped plugs as Jughead stated i think the kit i use is by save a thread also and came with a tap, punch, and some different size inserts. Never had a problem with them coming out and I've done several.
