Even though it's not a joking matter, I was just funnin.
Sorry.
I just like huffing gas.
I asked the guys I work with this morning if they think a good smelling chainsaw would be cool, were gonna zip tie air fresheners to the air filters.
It was like a scene from a movie...
This sucks for NE guys. We need to fix this eth problem with a cheaper source. I'm not running canned fuel in my mill. I hate eth. Only thing local besides E10 or E15 is fuggin E85Nope. Went through all of this last year. Not one place in new england that I could find. I called every marina on ocean and lake. Only places that have it are airports. 100LL
But they wont sell it to me. Guy looked out the window and said no wings, no fuel. Lol
Believe me, I called every single place!
I use canned fuel. VP SEF. Buy it by the 5 gallon can. Stuff aint cheap.
That would, was always, will be my future choice for some dip110 Sunoco, purple in color, smells real good.
Your problem was lead pills. They are not what you think they are. Lead but, by no means soft after the burn. Cut it with pump high test 50/50, run it only in nikasil or cast iron cylinders and you'll be fine.I have read avgas is super bad in two strokes, they have antifreeze qualities formulated into it and that breaks down premixes, and some mixes will separate, back in the day I use to avgas in my banshee and 250r’s I ran it for a long time! Then I read an article on fuel in a quad magazine, I made the switch to race gas and the change was amazing! At the same intervals the piston and bore wear was much less, much less scuffing and tiny scratches! I will never run avgas again! Plus it is formulated for high elevation, and that isn’t as good for things on the ground! Lol
I am still not going back, lol, if I did anything I would cut race gas 50/50. I build my 250r for 110, so that’s what I have around, and and am happy with it I run a few of my old saws on it because I also mix 32:1Your problem was lead pills. They are not what you think they are. Lead but, by no means soft after the burn. Cut it with pump high test 50/50, run it only in nikasil or cast iron cylinders and you'll be fine.
