Has the 661 been proven like the 066/660?
Wood Doctor
Edwin
10:18 AM
Omaha, Nebraska
I do have one 6.4 oz bottle of Stihl 2-cycle engine oil left. It's empty. I use that to measure out my next dump of another fuel mix brand into an empty 2.2-gallon gas can that's sold by the quart. Then I add the gasoline at the pump to fill the gas can. Works every time.
ursinykb24
11:18 AM
US
Does gb have a 36 Inch bar or something around that size if so where would I find one
Sent from my SAMSUNG-SGH-I337 using Tapatalk
11:18 AM
Well boys wont be long now I ordered a max air filter and some other whatnot's for a saw I don't have ....yet. Will be getting the saw with in the next couple of days.
Next thing to do is punch in the oiler pin. Before I did that to this one oiling was meh. After doing it it oiled as good or better than my 385.
11:18 AM
I will only be running a 28" bar for the most part will I still need to push it in?
It’s very easy to do, look near the adjustment screw, you’ll see a pin next to it. Punch it in flush by tapping on it with a suitable punch or screwdriver using a hammer gently. It simply allows you to turn the screw out roughly 1/8 turn more. Which does make a noticeable difference imho. Just watch the oil tank to make sure it doesn’t run dry before gas. You can compensate by adding slightly less gas.
Redfin
Meh...
11:18 AM
Central Pa
No worries on oil running out first if both tanks are full.
11:18 AM
Not sure if they are available for it, but I prefer the Stihl Winter Filters. Currently running them on several saws (044 - 660)
I just repaired a 046 recently that had a “metal” mesh filter. Fines caked in the intake. I replaced it with a knockoff paper filter. I’d go max flo for work and use the metal filter for a gtg setup, but that’s my personal preference.
11:18 AM
Jeff, the 440s and 460s don't need a pin punched, you can adjust the oilers from the bottom with a very small (like tuning) screw driver. It only moves about 1/3 of a turn. Clockwise is all the way up. 440s are rated for a 28" bar, 460s for a 36".
If you have any Stihl ES Light bars, I drill the oil hole in them (1/8"), that is the sticking point with them.
