- 5:48 AM
- Jun 5, 2016
- Northwoods of Wisconsin
Cool, thank you.
The meteor piston will be here tomorrow and I can start working on this thing. I measured the squish with the stock piston and no gasket, it didn't squish the .025 lead wire I use. So, should I cut the squish band unit I have a certain amount of surface area? like a ratio that relates to the area of the bore? and then cut the base until I have the squish correct?
And this is assuming the new piston measures like the replacement. I will measure the new one first
I would recommend you do your figuring from the piston that you are going to use. Even a new OEM one could be slightly different, not often so, but it happens.
