2000ssm6
SPF 1/29
Here is your chance to own a piece of history, 440 ported by Mike himself. This saw is fairly clean and runs great, pulls a 28" full skip/8 pin well. The oiler went out last year and caused some heat build up around the inside clutch cover. The pump was replaced with a new OEM unit and it has been fine since. It will come with the Maxflow or factory HD setup, your choice. If you plan on doing a lot of cutting, the Maxflow works much better than the HD. That cover does make a beautiful saw look like crap though. Decomp is plugged and you will need to be 100% committed when pulling. The commiefornia clutch cover came off my smashed 044 and has a chunk missing out the rear, the rubber guard is gone also, all visual as it functions fine and clears noodles nicely. It has always been ran on a slightly rich 40:1 no corn/Klotz mix. Build date is 2004.
$625 shipped PHO to the lower 48. No trades. Can call or text nine one zero, 610, three 0 six nine
