jaed.43725
- 1:21 AM
- Jun 10, 2018
- Central NC
So a few months back I picked up an unknown mower that says Golden Anniversary on the front of it. Turns out its a Murray. It has an old white B&S 3.5hp engine, as well as an actual throttle cable. I had to drop it off at a small engine shop and they did a full service on it. The tank had a leak, they replaced it with another one (I dont care if it matches), sharpened the blade, oil change, carb clean, new plug and wire, compression check. And the muffler broke taking it off, as it was barely holding on. So I took it to a machine shop and they got it out. Got a used muffler and screwed it in. And I tell ya, this thing beats any of those new mowers, any day. Its lighter and cuts better. And I can leave it running while I pick up sticks or whatever. Best part was I got it for free as part of a deal with buying a Lawn Boy 2-stroke for $30.
The only thing left to fix is wheel wobble. It has actual metal sleeves in the wheels, not plastic. So a good hardware store should have the parts.
