Crzybowhntr
Apprentice Slacker
I picked up a supposed non running generator yesterday and managed to get it running by just ADDING gas to the tank!! Anywho, the genset will not produce power. Anyone ever try to excite the generator by using a corded drill?
Electric Drill Method
The reason this works is because the electric motor in the drill will act as a small generator when spun backwards. The magnets in the drill's motor induce a voltage into the motor winding, which is fed back through the trigger cord and into the generator receptacle. From there it goes into the power winding of the stator. The voltage going through the power winding creates a magnetic field which is intensified due to the iron core of the stator lamination's. The rotor intersects this magnetic field as it is spun past the power winding, thus inducing a voltage in the rotor winding. Once current flow is present in the rotor winding the rotor has been flashed.
- Plug in an electric drill into the generator receptacle. (No @dall you can`t use a cordless drill LOL)
- If the drill is reversible, move the direction switch to the forward position.
- Start the generator.
- While depressing the trigger on the drill, spin the drill chuck in reverse direction. This will excite the field and the generator will now produce electricity. If spinning the chuck one direction does not work, try spinning the chuck in the other direction as you may have the reverse switch positioned backwards.
