Yea, I thought of that, really don't even need to flip the key, just align it on the opposite side.
But I tightened that flywheel really good, so I at least want to see how it cuts where it is before I change anything.
I was also thinking the carb could be leaking again, but it did pressure test at 10 lbs before I reinstalled it. I know the Hi is set too rich (on purpose), I can hear it, and see in in the plug. Will adjust that soon.
If it runs like a Beast, it may be worth keeping it like this. If not, I'll start changing things till it gets more civilized. It is very well mannered after it is running, smooth idle, etc.
I took the 7 pin 20" bar set up off and replaced it with a 8 pin 24" bar that should give it a bit more of a challenge. If it ever stops raining, I'll try and test it out.
