BuckthornBonnie
- 1:12 PM
- Aug 22, 2016
- Penn Yan, NY
The “bar” holding the piston in is called a wrist pin or piston pin. There’s no guarantee that it will work in an aftermarket piston (even Meteor). It will probably fit, but there are sometimes differences depending on the batch or saw model. The Meteor supplied pin works well and may just be a bit heavier than OEM.
I usually use a new OEM wrist pin bearing for top end rebuilds.
Did you turn the saw over a lot with the cylinder removed? Sometimes just doing that will cause the harmless mark you referenced before. The connecting rod smacks that part of the case if it’s not held true by the cylinder.
