Wood Doctor
Edwin
- 12:08 PM
- Feb 9, 2016
- Omaha, Nebraska
Owner said it wouldn't start and was lacking power before it died. I checked the compression -- rather good for an old warrior. Spark was good. Fuel filter and fuel line were good.
However, I noticed it had a hard time filling up the primer bulb (purge pump). Looks like it had been run many times without using the primer bulb to start it. Carb would drain it dry after an attempt to run. The bulb also had a hard time filling even though the bulb was clear. So, I replaced that and the short fuel lines that fed it. Saw then started immediately and ran like it was brand new.
Things like this always amaze me. One has to wonder how many good 2-cycle engine equipment winds up in the landfills this way. Any comments?
