Installed this craigslist find Baby bear in my hunting cabin a few months ago.
A friend welded the base out of C channel.
Double wall pipe.
Came out pretty nice I think.
Perfect size for my cabin.
View attachment 164355 Installed this craigslist find Baby bear in my hunting cabin a few months ago.
Double wall pipe.
You might want to check clearances, I’m pretty sure unlisted stoves are 36” clearance to combustibles. Even with a wall shield I still think the double wall pipe and stove are too close. I think you also need a crazy R value base for unlisted stoves. Metal will radiate heat right to the wood floor, you need something to insulate the heat from the floor. You also need 16-24” of ember protection in front of the door of the stove(depending on local code)
Hmm....
The stove pipe calls for 6" to combustibles. I pulled an old pdf scan off the web and the install meets 197x specs.
Luckily for me, it's not getting inspected.
The stove is Non UL listed so any dwelling that is CO occupation is a no-go anyhoo.
I remember owners of these stoves in Connecticut telling me that the Fisher Baby Bear performed as well as any stove made in Sweden. The Baby Bear was a Best Buy all the way.
The Fisher stove story is pretty interesting. First US made commercial airtight stove. The business model was unique and it worked well.
EPA regs eventually killed the company that was said to be unkillable due to its unique quasi distributor business system.
