Buy Used Saws CCC Ebay Store
Firewood tractors
Discussion in 'Tree Work Equipment' started by Ryan Browne, Oct 3, 2016.
  1. chipper1
    chipper1 Pinnacle OPE Member
    Jun 25, 2016
    3,382
    9,533
    330
    Grand Rapids Mi
    Did someone say brush hogging :).
    Just did some at the neighbors and then pressure washed everything, put the skidding winch back on for the weekend, now I need to put the hog back on again :confused:, at least I have it though :b1:.
    XP for Life likes this.
  2. Ryan Browne
    Ryan Browne Pinnacle OPE Member
    Sep 4, 2016
    1,665
    6,328
    334
    Wisconsin
    I feel your pain when it comes to swapping implements. Even with two tractors I usually make at least one change a day this time of year. Swapped the tiller for my SSQA/3 point forks today and moved some racks of slabwood I cut up.
    XP for Life and chipper1 like this.
  3. chipper1
    Jun 25, 2016
    3,382
    9,533
    330
    Grand Rapids Mi
    Those forks and the tillers are pretty easy for me, the skidding winch and the brush hog are a bit more work :confused:.
    Guess what I did today, yep I put the brushhog back on and got it all dirty, at least I got paid to do it :b1:. It will be fun tomorrow getting the wire that's caught up in it off, hope it's not between the blade and the stump jumper.
    Ryan Browne likes this.
  4. Ryan Browne
    Sep 4, 2016
    1,665
    6,328
    334
    Wisconsin
    Adding a hydraulic top link and side link has been the greatest help when it comes to hooking implements up. As long as I'm kinda straight-on and can reach the upper bracket with my top link I can then pull the tractor or the implement by reaching up and pulling the lever for the top link. I also use the side link adjustment. Hard to describe exactly when it comes into play, but having levers that I can reach from the back of the tractor makes it a lot easier. Plus, then once it's hooked up, I can make those implements do whatever I want from the comfort of my seat. :)
    chipper1 likes this.
  5. Nutball
    Nutball Super OPE Member
    Oct 31, 2018
    465
    1,262
    193
    Mt. Juliet, TN
    Ideally you leave some long pieces to extend the bottom of the bucket and stuff the sides well supported to get near vertical sides and maximum load, if all you have is a bucket and no fork lift. Small pieces vertical to extend the back of the bucket higher would be ideal too if it works. I haven't tried yet. I think I've done better using bigger chunks, but still a good load. Maybe keeping some planks along to build extensions would be ideal too, but then that might also take up too much space that could be firewood. It's a fun puzzle.
  6. Slacker
    Slacker Hunny Locust Skipchain Sparker
    Feb 3, 2019
    106
    295
    103
    Durham, Mebane NC
    Top and tilt are awsome, especially when I'm using the scrape blade. Cleaning ditches and crowning a road is tough without the hydro side link.
    Ryan Browne, chipper1 and hseII like this.
  7. chipper1
    Jun 25, 2016
    3,382
    9,533
    330
    Grand Rapids Mi
    That would be nice.
    Glad it went well last night, I was able to change them out in about 20min, would have been about half that if my son was there to help, having a hydrostatic tractor makes it easier to since I can bump the controls without getting on the machine, but controls out back would be sweet. I'll be swapping them again today again most likely, I need to do some work with the loader at a neighbors then I may drop a couple trees next door later this week that I'll use the winch on.
Loading...
Share This Page
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
