PogoInTheWoods
- 9:43 AM
- Apr 23, 2016
- Ohio
Anyone successfully used one of the FarmerTec MS250 shortblocks on a MS210? They're decent kits and bolt right up but won't run fer squat..., at least the one I just built. Thought it had carb issues at first but it now clearly seems to be a timing issue which would indicate the crank keyway isn't correct for an MS210 flywheel.
Did a fair amount of research on the coils, cranks, and flywheels today and have come to the conclusion that the kit simply isn't compatible with the MS210 or the 021 even tho the HLS ad claims it is. Hell, may not be correct for an MS250 either the way some of the FarmerTec stuff is going these days. I don't have a 250 flywheel and coil to test it, but I can say that with the carb set pretty lean on the 'L' and the idle adjust set fairly high, I can get just enough revs occasionally when starting to reach the typical built in advance for it to actually hit mid to WOT and act normally while it's in that advanced range. Will not settle down to an idle from WOT, tho. Just dies. Will start right back up and sustain a high idle but any throttle whatsoever just kills it. Adjusting the carb at that idle setting yields very little change but will result in backfire at the extremes of what would normally be the 'L' jet adjustment range. Yeah, backfire.
All sealed with Dirko and tight as a drum leak-wise. Fresh 91 octane e-free fuel mix. It is an EZ-start, but I pulled the carb, flywheel and starter from an 021 with no change in results. Fuel delivery is fine and there's spark you could weld with. Just doesn't seem to be happening when it's supposed to.
Would be interested to hear if anyone else has run across this and how it was remedied.
