Pincher
- 6:43 AM
- Jan 26, 2017
- sw corner of twin cities mn
After having the complete saw parts kit sitting around for over a year, this below zero temperature made me decide to put the 440 saw together. I managed to install the crank and started to check port timing and sqiush. The squish comes in at .070 without base gasket. Timing is at IN72 EX97 Transfer 114. The question I have is there a taller piston option? Does anyone know the connecting rod length so I can figure out where the timing numbers will be at around .020 squish. Cutting the squish band does not look like an option by the ring of death. It looks like the top ring will be at the edge.
