redoakneck
- 5:04 AM
- Jan 20, 2016
- Ohio326
That is a good idea!!!Looks like you have room to safety wire those.
Similar to the keepers on a 2100!!!
Maybe there are long spacers inside to keep the torque?Aha,I see said the blind man as he picked up a hammer and saw .Those muffler bolts going through a sheet metal muffler never get tight enough to draw the bolt to the yield point .That's why they rattle loose .
Yes they are long spacers, like a pipe. I did have to drill the entire length of those spacers to get the bigger 6mm diameter bolt thru. I cranked them pretty tight too. The 4 times the diameter for aluminum threaded holes not true, those threads are probably 15mm long??, should be 24??Maybe there are long spacers inside to keep the torque?
Read what I said again.I said to get maximum holding power .at least 4 times .It's a muffler not a main bearing cap bolt . .The 4 times the diameter for aluminum threaded holes not true, those threads are probably 15mm long??, should be 24??
I'll find out this weekend, if it all fails then I'll take advantage of huskys new pricing for p/c kits!!!??? Really think this should work.
if you have place use theese timeserts or helicoils , if not use the welder , just after you finish cover the cylinder with something for cold slow then retaped a new thread
And the final answer is make studs, drive em into the jug,oh yeah with a Lil jb weld. Install spacers into the muffler and lock that mofo down with aircraft saftey nuts no not nylock nut. Aircraft safety nuts
The more options the better, the re-tapping seemed pretty darn tight. We will see!!!!
Great ideas!!! Thanks
Dude, those things are obnoxious on a saw!!! Prolly squirt some black grill paint on them.!!!you fixed it right. There's lotsa ways to skin this cat but you already got him. You should polish those bolt heads. Put a shine on that fancy bling hardware
The aircraft nuts are a pinch thread nut. Fastenal should also carry themThat would be the final answer!!! Where does one obtain these plane nuts???
Last time I was on a plane removing fasteners these uniformed dudes kicked my azz and asked a bunch of questions!!! They even spilt ma beer and didn't got me new one!!!
