Jimmy in NC
- 10:13 AM
- Dec 23, 2015
- North Carolina
So I recently picked up a CS 4400 from a member here. Great condition under the mung... only real mark is a chunk knocked out of the rear handle in shipping. Looking it over I thought it had very low hours..but the clutch spur drum is worn totally out. OK....looking for one and I see Echo lists a serial number break and two different part numbers and bearings. This means the bearing rollers are different size and a bigger or smaller clutch drum bore as the cranks (inner bearing race) are all the same.
Earlier saws used a floating small spline rim setup. I am either going to use this setup OR is there a 3/8 LP spur I can install off of another small Echo? Anyone have any knowledge on this?
Anyone have an Oregon cross reference or any other brand drum vs the $38 Echo drum?
