Hoggwood
- 5:13 AM
- Feb 6, 2016
- Above the 49th
@fordf150 can probably get you one.Anybody know where i can get a full wrap handlebar for a 590 I've called echo and they want the serial number for a 620. i guess thats the only one that comes with a full wrap im a lefty. Thanks dave
Has anyone ever successfully made a fuel line for a Echo cs 302s? My local guy had the fuel line in the tank, but I cannot find the one to the carb. The sharp 90 degree bend to the carb is where I am stuck.
i think those saws use 1/4 pitch chain.Thanks a bunch for your input. I have no idea how long this saw has sat without running. I cleaned it up a little, rebuilt the carb and set the point gap. I was actually able to salvage a oil line off a bigger echo and use it for part of the line. It had a flared end that fit on the carb good, and it didn't pinch on by the bend by the carb box. I used a small piece of tygon to connect it to the fitting by the tank. It is somewhat temporary until I (if) I can find a oem fuel line. The one I made seems to work because it is back to life. A few carb adjustments and I runs good. And the oiler works. Now to get it in some wood. Hopefully a tank or two with some good oil mix will do it some good.
Thanks again.
and when the points conk out or the condenser takes a dump a nova module can bring it back to life.It is interesting listening and feeling how a points ignition saw vs a electronic coil driven saw run. I can definitely tell the difference. Especially at idle.
And that is exactly what I did. I couldn't get this 302s to run good. I checked everything. Swapped carbs and stayed the same. So I was confident it was points or condenser. So I bought the little module. It wasn't easy finding a location to mount it, being a small saw. But I hot it in a safe spot. I reassembled it. Third pull and it spit. Fourth it fired up and ran like a champ. A little tuning and it will be a saw I can use for a long time. I want to get a couple tanks of fresh premix run through it to clean it up. I'm super happy with the results.and when the points conk out or the condenser takes a dump a nova module can bring it back to life.
with points ignition it takes very little cranking to achieve a hot spark and they can bite just as bad as electronic ignition saws.
