- 3:58 AM
- Aug 5, 2017
- Denver, Co
This Echo saw runs awesome and sounds great. It does has a cracked recoil cover on the front lower corner. It does have three bolts to retain it so it will work fine for use. If you are going to use it much, it might need a new fuel line, as the original is old, but not leaking.
I would like $100 shipped to Con. USA for this saw. I will probably just keep it otherwise if I can't get that much.
Thanks!
