Double pipe for Echo Twin
1:48 PM
This saw is awsome and I came across a twin like this with a chance to buy one a while back ( not running ) but was scared off buy lack of parts availability. Is it easy to find Echo parts there?
chy_farm
3:48 AM
Yokohama, JAPAN
Thing that sucks about the 510 is its a clamshell block but I like it
Yep agree for clamshell! Last month tried one on old Stihl 084, really sucked since I did not have this type of crank case puller in hand. But was able to do it with some 'modified triangler positioning' lol. I used these green marked thread holes for splitting them.
chy_farm
3:48 AM
Yokohama, JAPAN
chy_farm
3:48 AM
Yokohama, JAPAN
This saw is awsome and I can a across a chance to buy one a while back ( not running ) but was scared off buy lack of parts availability. Is it easy to find Echo parts there?
HelloDub thank you for watching and leaving comments, glad you got a good chance for one of her sisters there! No need to be discouraged with the lack of parts IMHO, you can fabricate some parts on your own actually in a way I tried some for her. Anyways these parts are very rare here too, so we old saw freaks more often have to make it, as far making a parts, a part of our enjoyment, lol.
My old girl came to me with dirt and scares on her too, see below;
Her brake band was missing;
and her brake post got a crack on the front wall;
Will show some more pics of minor repairs.
Chy
Dawnsman
2:48 PM
USA
Hi there guys since I saw the twin on here I was wondering if maybe somebody could educate me on th he twins a lil more. My question is
How many different ones are there I know of the echo 610 evl and the John deere cs 66 ar ed there more from echo
Sent from my SCH-I545 using Tapatalk
chy_farm
3:48 AM
Yokohama, JAPAN
This fabrication of pipes begins with designing, firstly visit JavaPipe site to download a file, then after installation fill out the factors in the dialog, and click! You will get a view like this;
Red letters illustrate the pipe, which I added here.
I put the Transfer Port Angle as 120degrees, but now I think I should have better chosen at least 110 for this. Shame was that I did not make a check on this with my flesh.
This means 130 - 120 = 10,
so the time gap between the exhaust-port-openning and transfer-port-openning was estimated as only 5 degrees,
while
the time gap between the exhaust-port-closing and transfer-port-closing was also estimated as only 5 degrees,
and they make 10 degrees in total.
But this 5 degrees of time gaps for each of the in and out ports seems, even for this small cylinders, a little too small.
I will check it when I have a chance to see her inside again in the future though, lol.
chy_farm
3:48 AM
Yokohama, JAPAN
Very cool, looks like you have quite a bit of time in that saw.
Thanks Deets066, I have been wanting to accomplish much faster response on triggers, yes I am quite soaked in saws, lol
Thank you for the info and the links I really appreciate it
You are welcome!
chy_farm
3:48 AM
Yokohama, JAPAN
First place the cut sheet on the roller and press it ;
Move it forward a little ;
Give it some good taps to better round ;
See it with a lot of care ;
Done!! ;
For smaller ends of the cones, you can modify the positioning of the roller, will post more.
Chy
chy_farm
3:48 AM
Yokohama, JAPAN
Modify the positioning of the roller for cones,
Place a cut sheet and give some good bending on both of the axial ends.
Bending_cone_01.jpg Then give bending to the rest with your hands.
Make an inner pad if needed, a baseball bat can be a good candidate;
Shape it to get better straight lines;
Chy
chy_farm
3:48 AM
Yokohama, JAPAN
Very cool Chy, this is some good work!
Welcome to OPE forum!
Dan
Hello Dan, thank you for nice comment and welcome, appreciate it very much. You seem to have a lot of professional skills for making pipes Dan, glad if you could show me here some links to your nicest works.
Chy
