WoodsliverDan
Mechanical Beaver Builder
- 1:36 AM
- Jul 30, 2018
- Michigan
I've got an idea to help the 7900 saws get a bit more oil on the chain, or at least make the adjuster screw last a little longer. Most have seen @jar944 oiler screw he turned out of 6160, but I realize that it is out of many people's resources. So, I plan to remove the end nub off of the plastic adjuster screw (this is what controls flow) and drill a small hole in the end to epoxy a small wire or weld rod in its place. This way I can make the end nub a bit longer and more than likely, more durable. Of course, filing the gear shaft end to a steeper angle as well. Tell me your thoughts..
