ffchewy17
- 2:44 AM
- Jan 18, 2016
- Lake Mary FL
I had a job today to get a dead live oak down. 42" diameter at the base, 50' tall. Working in Central Florida, 96 degrees today and full sun. Started the cut with a 7900 28" square ground. Got the tree on the ground and started bucking rounds, cut 5 rounds then had to noodle a section at the first major branch junction due to size. Saw ran out of fuel at the end of the noodle section. Went to fuel up, gas can was in partial sun, running 89 E-free @ 40:1 K2. After fueling saw started to finish next buck section and saw would not hold RPM. The saw felt like it was starving for fuel, surging at wide open throttle.
I had to pull out the backup saw MS461, and finish the day with out any issues. I've never had any issues with the Dolmar before. Pulled the exhaust off at home and no scoring on the piston. Have not tried to restart saw yet. I tune with a tiny tac. 7900 runs HD filter set up and dual port gutted muffler.
Could this be vapor lock? Have never had an issue before with any saw in the heat. Ran two more saws on the same mix for the rest of the day with no issues. I really like the 7900, but I kinda lost confidence in it today. Hopefully it's something I did and not a saw issue.
