StuntCockWelder
- 6:47 PM
- Sep 27, 2018
- Illinana
Three too many letters on the end of the sign in background. [emoji6]View attachment 177210 My 7900 “mutt” with fresh red covers
[emoji1786]
Absolutely[emoji1786]
Bet that's a fun way to make cookies.
YessirShes Perfect!!
Nice! That's the early prototype with the computer controlled carb. They were all supposed to be destroyed.
When I get back to logging again I’m gonna try to use the excavator to put a good size junk log in the back of my pickup... if the boss doesn’t mind lol
Forgot to tuck the connector inNice! That's the early prototype with the computer controlled carb. They were all supposed to be destroyed.
Blue loctite worksSomething I noticed with the zama on these and a 365/372 is the idle screw tends to wear out from use and vibration over time (poor design imo). The screw then backs out when your running it. Talk about annoying. I fix it by cutting a actual idle screw to fit that I take off my junk pile of carbs. One off a 51/55 or 394 carb works good. Just cut shorter to fit and grind a little off the throttle stop, so you can turn in the screw far enough that doesn’t rest on the spring. Takes a lot of fiddling around but it works and cheaper than buying a new carb. View attachment 177317
Being clean helps. Completely degreased.Sure, but wanted something a little more permanent. Should have had one in the first place imo.
