mettee
10:33 AM
Arizona
15595735522834657304760842733920-jpg.184334
1:33 PM
@mdavlee I know you’ve built a 7900 or two with a 046 piston. Just curious... is it something worthwhile doing or was it a experiment with what was on hand? Does it have more grunt or more rpm that way? I understand if you’d like to keep it to yourself.
mdavlee
Hillbilly grinder
1:33 PM
TN
It works pretty good depending on the use. Jack Chin has one I built like that next time you get up with him ask to run it. I know @Hedgerow runs real well with that piston and rwj. I’ve run it with a 9 pin and 28” full comp cutting hardwood. I never got a 50mm one done. Alan and Matt messes with one some but it didn’t work out as good for some reason.
1:33 PM
I'm not Mike, but I'll help. The skirts on most dolmar pistons are narrow. Something like 58% bore width on at least one model sticks in my head. An 046 piston skirt is a little wider. And about .050" more compression height.
The wider the exhaust port, the easier it is for the spent charge to get out. Translates to more hp.
1:33 PM
I’ll have to ask Jack about that saw next time I see him. Did you have to run a spacer to make room for the taller piston or just took it out of the combustion chamber?
Hedgerow
12:33 PM
Nuthin we did made that 7300 jug run any better than the original slug.
A couple were absolute turds.
thedude74
Bonafide & Stuff !!!
10:33 AM
Alaska
https://sleequipment.com/makita-genuine-part-038-130-070-cylinder-piston-cpl-dcs7901.html
There’s the link @SOS Ridgerider posted. I still have it open with a couple in a cart ready to go. Apparently it is the original 7901 cylinder with the updated 7910 piston? If I remember/read correctly.
100 vs 150 is a whole different decision to make than 100 vs 220.
Went to purchase this kit today....$96 shipping to Alaska! Dang it! Guess they don't use USPS flat rate boxes(or doesn't fit). Looks like I might be going with the HL supply NWT bbk kit and a caber ring. Maybe? Hell idk. Anyone use the NWT bbk kit?
