Dolmar 133
Chainsaw Jim
Con Artist LLC
8:53 AM
Springfield Oregon
A cheap puller from the auto parts store works. Flip the plate over so the flat side is up. Leave the nut on the crankshaft flush with the end. The only set back is you need to buy long bolts with the right thread size. You'll also want a better set of thick high grade washers. Screenshot_20180203-100315.jpg
Fruecrue
certified hand catcher
11:53 AM
Alden NY
How about installation?
Clean and degrease then set with a hammer and pipe or long socket?
Fruecrue
11:53 AM
Alden NY
if you want that puller get it sent to me and i will send it over and if theres anything you defiantely need let me know
I appreciate the offer!
I’m out now, going to pick up a harmonic balancer puller and improvise.
Seals are here and I’d like to get started.
Chainsaw Jim
Con Artist LLC
8:53 AM
Springfield Oregon
View attachment 110302 View attachment 110303
Pulled the clutch and flywheel with the puller @Chainsaw Jim recommended. Little bit of creativity and a couple love taps.
I’m once again surprised at how clean this saw is. To this point I haven’t cleaned anything.
I try not to break em loose with the puller alone. I use penetrating lube before applying some torque to it, followed by a light tap with a hammer. Usually the slightest tap makes it pop. If it don't pop with a light tap I'll load a little more torque on the puller and tap again. The older large Jonsereds sure can let go with a big boom, and the clutches can injure a person when they come loose.
Fruecrue
11:53 AM
Alden NY
That’s exactly as it happened, PB blaster and all. Tension and a few little taps, just for vibration.
Fruecrue
11:53 AM
Alden NY
There’s a seal in the oil pump. Need to order that one.A15B1C59-E67F-479E-983A-9A47E2922ADC.png
Fruecrue
11:53 AM
Alden NY
Ordered the oil pump seal.
Removed oil pump.
Then this little bugger put up a fight. Modified a cheapo battery terminal puller and got the job done.2D98E762-CD09-4111-B0E6-E1B51E139060.jpeg
