Do you prefer a 7 or 8 pin sprocket, and why?
wiersy111
3:43 PM
Centeral MN
Which do you prefer a 7 or 8 pin rim sprocket? What are the pro's and con's. I have used 7 pin sprockets mainly, and the only reason is because that's what we always used. I just put an 8 pin 3/8" on the Hutzl 360 I just built and it cuts fast.
Wolverine
dilligaf
4:43 PM
You're a bit young for that, no?
wiersy111
3:43 PM
Centeral MN
I am always pretty conservative on bar length and using a big enough saw. Most of the time I opt for overkill on the saw. My smaller saws are Husky 51 and 55 Rancher I wouldn't even think of an 8 tooth on them. But my big saws Stihl 044 and 660 I can't see a problem with an 8. For milling with the 660 it would be a 7. I'm just curious what others use.
Sent from my SM-G960U using Tapatalk
CR888
6:43 AM
Australia
It depends on what pitch your running, .325, 3/8 & .404 have different chain speeds in 7pin. An 8pin .404 is bigger than a 9pin .325 for example. Best answer to this is take the huge plunge (scary & expensive I know) and make the big decision to spend $3-5 on an 8pin rim sprocket. Fit it to your saw and see for yourself. None of us know the density of the wood your cutting, what chain setup you have etc, etc, etc. Its something you just gotta work out yahself.
Spladle160
4:43 PM
NOVA
10, Mo is bedder! Honestly I wouldn't have an 8 pin on a 3/8 20" 60cc saw unless I was cutting 10" and down in hardwood. maybe try and tune the chain for the 7 pin.
Stem
Professional Cup Stacker
4:43 PM
Pennsylvania
run a 8 pin on my 650 with the 25" or 28" bar & it doesn't seem to care lol 9 pin with 18" (avatar pic) bar just for grins.
4:43 PM
The big Homelite in my avatar only came with an 8 tooth .404 .One of my 125 Macs runs an 8 and one a 7 .The Husqvana 2100 runs an 8 tooth .375 on a 32" bar but it's 99 cc too . The medium size Stihl's with easy change rims I just run whatever trips my trigger at the moment. WTH you can change one in about 5 minutes .
davidwyby
Rural desert logging
1:43 PM
Extreme Southeast CA
Decided to try 8 on a ported 55cc on a whim…works pretty good.
A
lso wondering, with a 404 7 pin being about the same diameter as a 3/8” 8 pin, and 404 having more kerf/drag, how much 404 can a ported 3120/395 pull? 42”? 60”? I bought 3/8” for my 60” but 404 stay sharp would be better in the dirty dry hard eucalyptus
10:43 PM
7T is all I use and want.
I am mostly bucking turkey oak and higher chain speed results in slower cutting.
But, I have been told that I have no clue regarding processing hard woods by a member here so take it for what it is - just my own preference!
I do run 8T and 9T for fun, but that is all I deem it useful for!
Stock saws, full chisel round filed chains.
3/8", rarely .325" & .404".
Turkey oak mostly knotty, oak, beech.
Rarely locust, hornbeam, ash.
