treeman
New OPE Member
- 2:02 PM
- Dec 25, 2015
- spartanburg, sc
--save yourself a lot of money in damaged equipment, stress headaches, lost work time, etc, just do not use gas with ethanol in it. ethanol is the same as the alcohol in vodka, or any other alcohol we drink. ethanol easily mixes with water in the air and will absorb the water from the air. the water and ethanol then can settle out and oxidize metals. oxidized steel is rust. oxidized zinc and aluminum like in a chainsaw carb , will look like white powder. problem is that the metal can be lost/removed n a critical location around the jets, ports, etc, the ethanol also damages many rubber and plastic parts.
--if you get ethanol free gas from a pump that also dispenses ethanol gas-the same handle, nozel , then use at least one gallon in your car first, then put the fuel in your tank for your saws. so that you will not empty the hose full of ethanol gas into your chainsaw gas can. many gas stations have separate hoses/ nozels for different fuels. but some gas stations I go to do not.
