backhoelover
SERVICE MANUAL MASTER
- 10:13 AM
- Feb 10, 2016
- lincolnton nc
does anyone have video on using degree wheel on finding btdc?
Ill look.do you have a link?
I turned them out on a lathe .I used a compass wheel transfer made of mylar from McMaster -Carr,counter clockwise rotation mounted on a aluminum plate,360 degree .Two fender washers ,one on each side . I've made several ,sent one to Rocky J in Florida . I can't remember if they are 8" or 9" .So whaddya use to adapt that Summit wheel to a chainsaw crank?
I got a couple of spares kicking around in the garage, so looks like I'm good on that frontI bought one for like $10
I don't understand what is holding the wheel onto the crank. There must be some kind of extending piece between it and the crank end proper, since is rotating in a plane further out than the end of the bar studs....or so it seems to me.
