- 7:10 PM
- Dec 29, 2015
- Ontario, Canada
Saw looks like Serious Performance!In the second video when I start up Dall's saw you can see the saw pull the starter handle out of my hand. Here's what a lot of compression and to much timing advance will do to your hand. View attachment 41011
After its maiden run I checked the compression. 220 comp. Thats more then I was wanting. I also rechecked the flywheel key. I thought I had filed .030" from the key turns out I had taken .040". Don't know what I was thinking when I did that. LolView attachment 41012
What paint did u use?I completely stripped the cases. Sanded them down and painted. Stripped the recoil down and also sanded and painted itView attachment 40985View attachment 40986
