Innies? Like the plating is gone? If that’s the case then I’d quit wasting my time. But if it’s transfer.... then sand awayThose are inies, not outies.
Junk?? Keep sanding?? Run it?
Keep the acid on the plating and away from the port edges. It can undermine the plating if you're not careful just like the pic above. There was probably pits that it got into. Baking soda will neutralize it.I do have experience with acids just not this way. I'll get some and try, thanks guys.
I worked on it some more late last night, seems I have nothing to lose with the muratic.
How does the muratic react to carbon build up?
The stuff eats concrete.I do have experience with acids just not this way. I'll get some and try, thanks guys.
