So, it looks like a 6 rivet distance (center to end) would reach the next forward cutter on skip-tooth chain, and a 7 rivet distance would reach the cutter to the rear. Averaging out at a 14 rivet spread overall would be a 'safe', symmetrical base size. Since chain pitch (e.g. .404) is measuring between any 3 rivets, then dividing by 2, a 14 rivet spread on .404 chain would equal 5.656 inches (round off at 6 inches). That would be the maximum base needed for hand held saws.
For full comp (standard, non-skip tooth) chain, only a 4 rivet distance forward, and 5 rivet distance rearward is needed, or 10 rivet spread overall for a symmetric base. On 3/8 pitch chain, that would equal 3-3/4 inches. This is what you made, what I would use most, and would be more compact.
I think that I will copy your base, and make a supplemental 6 inch base that can be taped on below, if needed. Since the tool lets you zero out at any measurement, this would still be easy to use, and more convenient to carry or store.
Philbert
