always had bolens wide cut mower for years but no longer available so I got told cub cadet got the exact mower I've done 23hrs with this one and Iam well impressed side discharge or mulch
I like the caster wheels up front Andrew ..makes the turns less work i assume ? A early Hayter Condor I used was a bit of a grunt with the fixed ones . @ajschainsaws
