- 6:39 AM
- Jan 8, 2016
- Mandal, Norway
Yes Matt, instead of many spacers we use a socket.are those drawings just the spacers?
Tor... here's version 2.0 of my tools...
isnt those flywheel seals around 28mm in diameter?I made another socket the other day for the 390/385. Same basic dimensions as the 372 socket but the OD on the small end is a shade over 28 mm vs. 27mm. I think it will work a little better for installing the seals.
Yes they are. The socket that I made for the 372 is 27mm od and I wasn't comfortable pressing the 390 seals in with it.isnt those flywheel seals around 28mm in diameter?
got it, if I where to use the socket to knock in seals, 27mm is to little, but over 27mm gives to little distance to the crankarea where the seals are mounted.Yes they are. The socket that I made for the 372 is 27mm od and I wasn't comfortable pressing the 390 seals in with it.
Yes 17mm is correct.got it, if I where to use the socket to knock in seals, 27mm is to little, but over 27mm gives to little distance to the crankarea where the seals are mounted.
Since you are into 385/390 nowadays, what dimension has the PTO crank? 17mm?
thanks alot bud.Yes 17mm is correct.
I think there is about 23-26 crank mounting tools, not included whatever came out the last 5 years.i dont have a lathe . will one day . by then i will have bought all the husky crank and seal installer. their about 50.00 each give or take. and they make i think 30-35 different ones all together some are nla. i think i have 16 of them. the ones for the newer concrete saws come with 4 units that screw onto the crank i have used them on alot of other saws keeping me from having to buy other crank installers
What kits do you already own?
We are all here to share, end of the day some people improve our ideas. Well done work Matt.Thanks.....your research was pivotal here. So thank you!
Unfortunately ...as is...it won't cover the flywheel side for smaller stihls...because the seal pocket is too small. I'll work on it
