- 9:40 PM
- Dec 24, 2015
- Coastal Oregon
Max RPM is dictated by several factors -
What lubrication source the bearing operates in
Expected shock loading and side loading
Cage type
Number and spacing of ball or roller bearings
You'll find that most bearings have a higher max RPM range when operating in an oil-bath environment, as opposed to
being sealed with grease. The ZZ rated Nachi bearings max RPM is 18k on grease and 21k in an oil bath environment (the crankcase
of a modern saw qualifies as an "oil bath"). All of the major brands (Nachi, SNR/NTN, SKF, Fafnir, KBC, slacker, Timken) make a
quality product and have been a supplier to the major OEMs at one point.
Where the bearings are made is generally more important. I've seen SKF bearings made in Turkey, Portugal, and Argentina.
Those made in Portugal and Argentina appeared to be a higher quality product than those made in Turkey. SKF is a long
time supplier to Stihl and SKF bearings appear in all of the larger professional model Stihl saws. KBC has bearings made in
South Korea, Taiwan, and China - with those made in South Korea and Taiwan being a better product.
Read the spec sheets put out by the manufacturers - they contain a ton of information.
Cage type
