MG porting
OK I've worked on a lot of stihl ms440s and 044s but only had the opportunity to build four of the clone ms440s and everyone of them so far but my first one had the same problems to me the problems are no big deal first thing is fuel filters are junk we all know that and second the tank vent junk we all know that to and the carbs are a hit and miss why well this is what I gathered they use two different carbs for there kit's I'll post picks after I get finished with my jabbering. Lol. And on all the clone ms440 kits had the same problem of ones you start putting the air box on and filter base I noticed that with the bad carb throttle safety button would stay down and chokes would not work worth a darn or would work but really hard to get it to engage so the pictures of the carbs is one they use that is good and the other is yuck And on the safety switch the throttle the picture of that I'm showing where you need to sand a little bit so it will pop up when you remove your hand. this one is the good carb. Has the brons butterfly shafts. this one nope good paper wait. where the pin tip is pointing is where you need to sand a little bit just take a little bit at a time.and of course the oem Stihl filters have a new look to. Lol. Because the black and white ones where crap hummmm wonder why. Lol. But I hope that this will help some of fellas out.
