circle crank ms660
Moparmyway
Its just a saw
11:38 AM
In a meeting
So, opening the transferrs where they flow the most and making them flat at the top, while raising the exhaust to increase blowdown and raising the intake to trap even more ..........
Do you think the circle crank or the 288 piston is making this one run so well ?
jmssaws
Banneded
10:38 AM
I haven't taken advantage of the 288 piston yet so I'm thinking it's all velocity.
It's as strong if not stronger than a ported saw completely stock. It does have compression but that's all. The carb still has the limiter caps. Lol
awol
10:38 AM
Cabool, MO.
The main advantage of the extra skirt width, is the ability to go wider with the intake and exhaust port. Adding fingers will not hinder that, plus the single ring, gapped over the intake port allows both a very wide exhaust, and nice deep, wide fingers.
Redfin
Meh...
11:38 AM
Central Pa
This is 80 and as wide as I was willing to go for ring support with a 288 piston. I suppose I could have gone further at the bottom. I could have gone further without the fingers and Im now wondering if fingers was a good idea with this piston.image.jpeg
jmssaws
Banneded
10:38 AM
I'm gonna put a few tanks through it tomorrow to limber things up then do some grinding.
How wide of a exhaust have you guys gotten away with?
