Christmas build # 2
Stihlbro
7:53 AM
Virginia
Does it have the thick plastic piece on the fuel side?
Deets066
AKA Deetsey
7:53 AM
It's suppose to have the plastic elbow like yours, it was missing when I got the saw. It has a short knurled barb sticking out that the elbow was suppose to go on
7:53 AM
Joey,
What's the difference between the 43A vs. 43B?
I know that the Tilly is supposedly to run better, but I never realized that the bore was larger.
Can you measure that for us?
Deets066
AKA Deetsey
7:53 AM
Joey,
I can a little later, I bet they are real close in bore size
big t double
You can call me Teddy Eastwood.....
6:53 AM
If you need someone to run that Xmas saw before you send it...you know, for perspective...I might know a guy. Looks like a runner sir. :D
Stihlbro
7:53 AM
Virginia
Joey,
I'm not sure on the a to b differences.
The throttle side is the same from zama to tillotison. The Venturi is larger on the tillotison .
paragonbuilder
7:53 AM
Norwich, CT
36 idles a lil high but it only has two clutch springs
Looking good Keith!
How would an additional spring slow the idle down. You should be able to slow it down even with no bar, no? Sounds like you are up in the high 3k's
Deets066
AKA Deetsey
7:53 AM
Looking good Keith!
No air filter
1 broken clutch spring
Modified carb
It will be fine when my new springs get here and I put an air filter back on
Deets066
AKA Deetsey
7:53 AM
The bore was .006 bigger on the tilly compared to the zama
