Chainsaw Jim
Con Artist LLC
- 2:52 AM
- Feb 8, 2016
- Springfield Oregon
I'm assuming so based on the conservative numbers I started with. There's a few other things that will need done. I would really like to modify an 1122 poly flywheel and coil to fit. Another thing would be a full circle crank.Looks faster Jim, still more to come?
Is that an 070 cylinder?
The 66mm one I'm working on has no transfer bulges out the bottom like yours. I wish this thing was mine so I could get crazy with it. Maybe one of these days I'll get my hands on a REAL one.Nows when I should say it's a 10 cu cylinder , but I can't the cylinder has been welded and the the transfers were dropped out (it's 66mm) Ran it a couple times Years ago, going to pipe it this time, just waiting on Chinese parts and other parts.
I bought a spare oem 090 jug off the bay for $30. Had a tap broke off in the exhaust bolt hole. Pretty good shape other than that.The 66mm one I'm working on has no transfer bulges out the bottom like yours. I wish this thing was mine so I could get crazy with it. Maybe one of these days I'll get my hands on a REAL one.
I don’t believe any of that is gunna be there in the end.Plugging that decomp hole is equivalent to cutting .021" off the base if my math is right. 4mm x 9mm
