- 9:44 PM
- Dec 30, 2015
- Brewster, NY
I'm really curious how the Blue saw will do against the Cross in wood!
Still have to fix the high idle, so if anyone have any sugestion i am all ears!
Yes, it is! Have to check my blue one, high idle works on that one. Should not be to hard to copy.I think an OEM control lever may fix the problem, but Huztl came up with a different fix. If you look at the carb in the Blue saw you will see it.
They added a metal piece to the carb that locks the throttle when the choke comes on, and releases when you blip the throttle. Don't know if these carbs are sold separately? IMO, it is a very smart fix!
So am i! I dont have any wood for another month or so, but will ask around to see if someone have, and need some "help".I'm really curious how the Blue saw will do against the Cross in wood!
Hi to everyone on here. The first ms 660 from huztl I built couldn’t Get idle to come down as many had the same issue after some investigation I bent one of the bends on the rod a little more. Problem was gone. Plus an oem throttle and selector shaft for your high idle
It was the starter cover that broke. Must have been a faulty casting.What happened after the tenth time the starter rope broke??
