Wisconsin Welder
- 10:31 PM
- Nov 28, 2018
- S.E. Wisconsin
This 066 was the one that ate a ring last week that you may or may not have seen a post about. A Meteor P&C showed up from HL Supply today and heres where it shakes out with no gasket.......
Squish is right at .021" everywhere I measured it.
94/122/82
It seems to me that the whole thing needs to go down about .065"-.070" to get the exhaust to the 100 range, and at that point I would be raising the intake floor with epoxy. I'm guessing that the transfers would come up less degree-wise because of the crank position and inches of stroke per degree on the crank at that point.
Does this make sense? Part of me also just wants to run it like it is, everything seems ok except the exhaust is kinda high. I can machine whatever I want but I don't have right angle stuff to get at the upper transfers if they had to come up.
Thoughts? Opinions? Sandwiches?
94/122/82
