David _4
I'm looking to get a new compression tester and I know there are other threads covering this topic, but I wanted to share a reply I received from an engineer at Lisle Corp.
My question to Lisle,
I'm looking at your 20250 compression tester to use on 2 cycle chainsaws. The question I have relates to using thread adapters. I need to use the 10mm thread adapter for the chainsaws I'm testing, does the use of a thread adapter on a small volume combustion chamber alter the compression reading vs using no adapter. I have been unable to find a reliable answer to this question. Thanks
The reply I received,
David,
Using different adapters does not affect the compression readings. About the only thing to affect pressure readings is to use a longer hose adapter.
Thanks for asking,
Randy Ploeger - Project Engineer
Lisle Corporation
Clarinda, IA
David,
Thanks for asking,
Lisle Corporation
Clarinda, IA
