How much $ do you think you have in her all together if you don’t mind me asking?Too late. They are.
My Saw is a DQ from beginning. It's got OEM:
Crank
Dominant ceramic bearings
Pin bearing
Meteor piston and jug
Flywheel
Coil and lead
Boot/clamp/carb
Fuel line and filter
Crank sleeve/spacer
Oil pump and worm gear
On/off control switch and lever
Entire brake assembly exc handle
Exhaust gasket
Badges
Clutch cover
Air filter
Clutch/Drum/washer/Clip
Starter center/pawls/new elastostart
And recently impulse line
Easier to list what's still am
And that stupid ass impulse barb is causing all the problems. It's nuts.
My carb is a new HD50 as well.How much $ do you think you have in her all together if you don’t mind me asking?
I completely agree with @drf256 the kit saws just don't make sense to me, the juice just isn't worth the squeeze, I keep saying it, buy a oem project saw and build it, then you know what you got, just my 2 cents.
I strongly disagree.Then it’s really more about operator
Maybe you can send it up and I can do some port work for ya, but I'm kinda backed up at the moment ...
I can say plunge cutting with race times involved could lead to a shítload of bad injuries. Some could be fatal.I strongly disagree.
Pretty much, yes.WTF. One small part causes all the issues?
