Chains information
afleetcommand
7:58 PM
CNY
I know the subject is in here somewhere so maybe point me in the right direction or we can do a repeat...wanting to try going run .325 on a modded 60cc class saw with the sprocket diameter larger for higher chain speed. Wondering if there is a weight difference in the entirety of a system...ie. Bar&chain& sprocket vs. just going 3/8 and a light bar. AND is there any benefit in cutting speed in hard wood along with changes in wear time. I had heard Oregon was going to release a new series of chain, don't know if that fits into the discussion as well. Might be a fun project to do, just comparing different chain setups....BUT if anyone already has, why reinvent the wheel?
7:58 PM
.325 is normally slightly narrower, but it has more drivers. That may negate the weight difference.
Some smaller saws are faster with .325, some with 3/8. I'd think you'd be better with 3/8, given its a modded 60cc saw.
The added space between cutters, coupled with taller cutters, would also allow more chip clearance, which would come into play somewhere around 24" dia wood.
jakethesnake
I Am The Snake
7:58 PM
Here & Now
Yep. For the hell of it stihl chain seems to be the fastest of the 325 the cutters seem taller. I don't personally know if that is a true fact just seems faster and taller to me. I don't even like stihl chain however the one loop I have I keep on a 346 because of the aggressiveness of it. It could be in my head I tried stihl chisel vs Oregon chisel. Just seemed faster outta the box. I'm pretty confident I could tweak either one to outcut the other but fresh brand new the stihl is more aggressive and grabby
jakethesnake
I Am The Snake
7:58 PM
Here & Now
Personally I think on a hot 60 cc the 3/8 will be the performer Hold up longer most likely be faster 325 to me is for the lighter saws the 346 I could go either way it's ported and has some nasty to it Only use 325 to keep the number of different size loops down
jake wells
no longer here
6:58 PM
ky
a couple of the Oregon speedcut bars arrived but the chains to go with them are on backorder yet again, I planned to try them on a few "purely stock" saws for the heck of it
Dave
speedcut chain is available through loggerchain.com i believe.
jake wells
no longer here
6:58 PM
ky
i use stihl 23rs or 26rs personally seems to me oregon 20lpx and 22lpx has went down the drain in quality
same applies to the bigger 3/8 oregon chain. i pretty much try to use stihl chain these days.
others here seem to have better luck with oregon chains here than i do.
RI Chevy
7:58 PM
earth
You ever try Carlton chain Jake? Very hard cutter. I like it.
I would go 3/8 all the way on the OP's saw.
RI Chevy
7:58 PM
earth
Yup. Me too. Works well for me.
LOL, just realized there are 2 Jake's responding here.
jakethesnake
I Am The Snake
7:58 PM
Here & Now
I did stock up on some Oregon due to left coast having that big sale. Preference is Carlton though
RI Chevy
7:58 PM
earth
Same for me. Oregon is fine as well. One could not avoid stocking up with that web special price. Awesome deal. [emoji106]
Khntr85
7:58 PM
Indiana
I also bought some of the 3/8 Oregon chain on sale at left coast....I haven't used the 3/8 yet....but I did use some .325 Oregon full-chisel yesterday....
Before I went to cut I ground the .325 full-chisel chain on my new Oregon 520 grinder....i used the down angle adjustment for the first time, and it worked very well..... I put the chain on my 026 with an 18" bar, and it cut the white oak I am cutting great....I went threw 2-tanks of fuel and it was still cutting great when I finished for the day....if the Oregon 3/8 chain holds up like the .325(which I think it will), I will be very happy with the Oregon chain!!!!!
jakethesnake
I Am The Snake
7:58 PM
Here & Now
I think Oregon may have had a bad batch or two years ago. The more recent stuff I've used has been good to me. I got several loops from a member here last year. Good stuff If you're cutting green wood I don't think it much matters what you use. It's that old dead standing oak that really tests a chain out
Khntr85
7:58 PM
Indiana
Ya I was shocked it didn't stretch at all....I sure hope the $15 dollar 25" loops I got hold up the same lol....I also got some 20" loops for $9.99, heck you can't go wrong there!!!!
Simondo
11:58 PM
UK
If your interested....I did a bit of swapping about with sprockets..chains in the .."Fat ass dolmars" thread in the chainsaw forum. About page 12 onwards I think.
