Pincher
- 1:08 PM
- Jan 26, 2017
- sw corner of twin cities mn
Lot of people tell me that you can't do that! The trick is to 'file as you grind and grind as you file'. If your ground cutter profile is very different than your filed profile, you will waste a lot of time going back and forth.
Even if your mayor or our governor tell me I cant, I still will cause it works for me. My filing might have improved to be closer to the grinder. My best cutting ground chain was touched up with a file before use.
Now to learn square file...
