- 11:20 AM
- Dec 28, 2015
- Central Ohio
Should be more like 65mm bore if it's 42mm stroke.62mm bore 3120s?
Stroked as in rod changed out? Or entire crank?They are bored and stroked indeed 62mm, have to use the oem cylinder in most races.
Mine arrived today, anybody got a pipe i can borrow ?
Here’s the pipe Dave. How much you need?They are bored and stroked indeed 62mm, have to use the oem cylinder in most races.
A rod change doesn’t change stroke. But will change rod angle.Stroked as in rod changed out? Or entire crank?
Yup, but that wasn't the point of the question.A rod change doesn’t change stroke. But will change rod angle.
Ah gotcha nowYup, but that wasn't the point of the question.
Most guys start with the OEM 3120 crank, but not all, the range of rods used is pretty diverse as well. Falicon in Florida built mine from OEM 3120 crank and a new 084 rod which is a popular choice because they are light.Stroked as in rod changed out? Or entire crank?
Dave do they limit to oem jug now?
you guys gave me that rain jacket the week before and it came in handyWho's the guy in the Orange jacket recording the video. Looks familiar??
