Best Buy Co, Inc. Buy Used Saws CCC Ebay Store HLSupply Daily Deals
Building a wood shed, vapor barrier???
Discussion in 'Our Firewood Forum' started by redoakneck, Oct 22, 2018.
  1. redoakneck
    redoakneck Pinnacle OPE Member
    758
    1,480
    208
    Ohio326
    I'm building a wood / hay IMG_20181022_133959217.jpg shed and using metal for the roof, will be open on at least 2 sides, 11'-8' feet tall.
    Is a vapor barrier needed??? Does it protect the metal from treated lumber???
    Cat 525 and RI Chevy like this.
  2. Deets066
    Deets066 AKA Deetsey
    11,348
    49,742
    516
  3. RI Chevy
    RI Chevy DollyKitaStihlvarna Runner
    May 7, 2016
    16,001
    36,099
    473
    Ocean State
    I have never used a vapor barrier in that instance.
    Wind running through it should keep it dry.
    Cat 525 likes this.
  4. redoakneck
    758
    1,480
    208
    Ohio326
    Thanks, kinda what I thought since not a heated or ac building, just didn't want to see the metal get messed up from pressure treated wood . I know that I don't need pressure treated wood because it should stay pretty dry under the roof, but I have those wood/ carpenter bees that invade soft pine pretty bad
    Cat 525, RI Chevy and Deets066 like this.
  5. Deets066
    11,348
    49,742
    516
    Painted or alumagalv sheets last a long damn time
    czar800, Cat 525, redoakneck and 3 others like this.
  6. RI Chevy
    May 7, 2016
    16,001
    36,099
    473
    Ocean State
    You could always put some stainless washers between the metal roofing and the wood. It would provide a little protection. Piece of mind for you.
    longleaf, Cat 525 and Dub11 like this.
  7. JohnnyBlade
    JohnnyBlade JUST GONNA SEND IT
    Apr 21, 2018
    602
    1,991
    198
    Momence,IL
    Never heard of this....what does treated wood do to painted metal? Ive been attaching steel electrical enclosures, panels and meters to treated wood for 20 years...
    Hinerman, longleaf, Deets066 and 2 others like this.
  8. paragonbuilder
    paragonbuilder Jon1212 Approved!
    Jan 2, 2016
    9,111
    32,870
    516
    Norwich, CT
    They condensate anyhow.
    JohnnyBlade and RI Chevy like this.
  9. paragonbuilder
    Jan 2, 2016
    9,111
    32,870
    516
    Norwich, CT
    If you are concerned, buy a couple rolls of zip system tape and tape the top of your purlins.
    And make sure your screws are rated for treated lumber.
    bryanr2, JohnnyBlade, Cat 525 and 2 others like this.
  10. redoakneck
    758
    1,480
    208
    Ohio326
    I have no idea, sounds like it isn't an issue???
  11. Dustin4185
    Dustin4185 Pinnacle OPE Member
    Oct 25, 2016
    719
    1,884
    208
    East TN
    The screws not being rated for ACQ lumber would be a greater concern than the painted metal to treated lumber issue. FWIW, the treated wood I used for facia boards on a small shed are getting eat up by carpenter bees as well. Also your dead load weights will be greater with treated. I would use #2 pine for everything except posts and bottom wall purlins if you are siding it.
  12. Deets066
    11,348
    49,742
    516
    Sounds like he’s using plywood, then sheets.
    If you wanted, felt paper is cheap
  13. paragonbuilder
    Jan 2, 2016
    9,111
    32,870
    516
    Norwich, CT
    I must have missed that. Yup if plywood is used felt is the easy answer
  14. paragonbuilder
    Jan 2, 2016
    9,111
    32,870
    516
    Norwich, CT
    It’s really not, they sell painted steel deck ledger flashing and it holds up fine.
    Personally I use copper. But painted steel does work.
  15. JohnnyBlade
    Apr 21, 2018
    602
    1,991
    198
    Momence,IL
    X2 what he said. All else fails use flexseal. Im mean they put a screen door in the bottom of a boat.........it has to work:D
  16. Homemade
    Homemade Pinnacle OPE Member
    Apr 8, 2017
    619
    1,492
    203
    Wisconsin
    The chemicals used in the pressure treating process cause accelerated corrosion on steel members. You can’t avoid the raw steel even if it’s painted or galvanized from contacting the pressure treated lumber, because you puncture the steel when fastening. Those are the facts.
    Now for my opinion. Don’t worry about it. I don’t think it will be much concern. If you invest in any moisture barrier, I would put in on the ground and burry it with 4” of stone to keep it from rotting the bottom row.
  17. redoakneck
    758
    1,480
    208
    Ohio326
    Wasn't going to use any plywood, steel roof on 2x4 horizontal pressure treated .
    Thanks for the tip on special pressure treated wood screws!!!
    farmer steve and RI Chevy like this.
  18. huskihl
    huskihl Sausage Fingers Forever
    12,350
    67,028
    549
    It'll be fine. Steel polebarn siding is screwed to a treated bottom skirt board on most pole barns. I've never seen an issue
  19. RI Chevy
    May 7, 2016
    16,001
    36,099
    473
    Ocean State
    Just use a stainless steel washer between the steel roofing and the PT wood.
  20. Deets066
    11,348
    49,742
    516
    That would be a pain in the asss and wouldnt keep the entire sheet off the wood anyway.
Loading...
Share This Page
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
